1000μl Wide Bore HIGH Tips
Hello everyone!
We received new Tips for us. '1000μl Wide bore tips, 3.20mm orifice without filter 10 – 1000μl
Conductive" Part Number - 235444. I notice that they are shorter than typical tips for 1000 such as “1000μl Standard Tips”. Does anyone has experience with that tips? I mean, maybe there is a way to create new tips, kind a file? Because the Software shows only this. See the picture. Thanks!
tips
Please refer to the following thread which provides a link to the installer for versions before VENUS 6.
Thanks! It helps!
Hi Eric!
Could also help with modification of 300 and 1000 uL Clear tips?
By this I mean, when I’m creating a method and need to add Tips, in my list I see only 300 standart + standart with filter ( and the same with 1000 uL tips). In liquid editior I found that I can change tip type, but theres no modification and in method it dosent wotk.
I hope you understand.
also I have “300μl SPECIAL TIPS Extra-Long and Slim Tips (10μl – 300μl)” Do you have any files to download this modification?
Please see the post below for how to use clear tips. In brief, you can use the definitions and LCs for conductive.
See below for links to the installers. Note, that these aren’t needed for newer versions of VENUS as they are included by default.
