I am trying to see if anyone still uses the Beckman BioRaptr anymore? If so, Are there any limitations you run into with the instrument?
Have not used it before, but I know the guys at Let’s Go Robotics have basically taken the discontinued BioRaptrs and retrofitted it to be more modern. Maybe shoot those guys an email.
This is very similar to the M24you nano dispenser, Formulatrix Mantis and UKrobotics D2. They are all really great pieces of engineering but the main limitations of use is they are bulk dispensers so you will need to clean out lines between different samples and reagents. So if you have a need to mix more than 8-10 reagents can be more hands on time.
The main advantage is speed of plate setup and the very low dead volume so ideal for very expensive or short supply samples and reagents. So large arrays of sample conditions can be screened at lower cost than standard liquid handlers with higher dead volume. They all work via a worklist input file so the programming has been standardised some what.
They are also in general lower footprint than most traditional liquid handlers so I have seen them being used in bio marker labs or formulations screening as they tend to have low sample volumes from animal studies or there is a need for wide array screening.
If interested, We have been successful at installing the BioRaptr software on Windows 11. Feel free to reach out service@dcmbio.com
The OG BioRaptr units use Lee valves which are soft closing. Certus Flex from Gyger/FutureDrop and our D2 dispenser (UK Robotics) both use Gyger AG hard closing valve technology. These valves close using ruby against sapphire. They have a long life & high chemical compatibility. IMHO the valves are the most important starting point to consider with a dispenser. If you can trust the valves this is a great starting point! … all the rest is just software and XYZ moves basically (huge simplification but you get my point!)
