After a maddening dive into HSLExtenstions::Sequence library I came across the use of count vs max; where if they are concat’ing a sequence with used poistions they use the GetCount(); to set the end positions. However when they are concat’ing a full sequences together they use sequence.GetMax();
This indicates that count != max at times! Though I do not understand when that would be the case or what the difference is from the help
I have tried, incrementing and setting used positions but count does not change!
What is “count” vs max!
Thanks,
cwehrhan
