Sequence_V3 Library Bug and fix
Hi Everyone,
I was running into a weird bug using the Sequence_V3 Library where on like 176 the file:open command to write and reorganize the sequence positions for channels was saying that the dummy.xls file did not exist.
I seem to have isolated the issue down to the “c:\temp” parent directory needs to be created for the file:open command to create a file when the parent directory does not exist. I ended up adding a step to create the “c:\temp” parent folder and then the step word as intended.
I think a guard band step could improve the step overall to check if the parent directory for the dummy file exists and if not, then create it.
Hope this helps someone else.
