Serial Number integration in csv file
Each hamilton STAR has a four digit equipment/serial number. If I want to use the same script in different hamiltons, is there a function to integrate the serial number of any hamilton when creating a csv file on VENUS for the data files that are released?
You can use the following library to retrieve the SN for a STAR, where the returned string can then be incorporated into the name of the files you are generating.
HSLGetSerialNumber - STAR
Hope this helps.
