Does anyone here actually use SiLA and AnIML standards?
So it looks the part and sounds the part, but I was just wondering if anyone here actually uses it and if so what for?
I’m going to be looking into data standards and standards in general that are used in the Automation as part of my PhD. Don’t want to be reinventing the wheel trying to get our equipment to talk to each other.
I’ve used it in the past for Tecan Fluents, I was particularly interested in the Tecan provided Python client. Initially I thought it was pretty neat that I could control a Fluent from a Jupyter Notebook but I was also very pleased by the ease of set up. I was able to move from testing communication out of curiosity to implementation of ideas in almost no time.
I believe LabVoice used the aforementioned as part of this implementation.
With that said, it’s fortuitous that you post this today because last week was the initial meeting for a new SiLA Demo Working Group, which aims to give…
scientists a way to test SiLA in their own lab and at the same ease as one can run free trial software could greatly help to establish SiLA as a standard.
This requires a well-chosen collection of pre-configured SiLA Implementations (aka apps) and a demo-workflow wrapped inside a single-file installer.
The demo workflow should be generic and useful even in the absence of special laboratory automation hardware, e.g. guide through protocols, identify and manage samples, read labQR codes, and auto-magically document results.
And so basically the goal is to move from creating standards to implementation of those standards with an emphasis on ease of use, hence a demo. The group is also a good opportunity to scope any further questions you may have. There’s also a Slack channel if you’re interested in that sort of thing.
From this forum, I think that @TimFallonUCSD has explored it as well.
This is a pretty good example of the implementation of a barcode scanner using a SiLA server.
Ok, that’s great info thanks very much! Will have a look at the slack.
Let me know if you need any links. Also follow Carmen on LinkedIn if you’re on that platform.
