New user here (both of the Hamilton Method Editor and of these forums), so apologies if this question has been answered somewhere else. One of the things I’m trying to do in my code is use the “SendEmail” command of the HSLUtilLib library; but whenever I try to run the simulation it gives me the following error:
“Cannot send email. Root cause: “Failure sending mail.” (0x4c - 0xc - 0x0) (0x23 - 0x2 - 0x39)”
From using the GetEmailAddressOfSender and GETSMTPServerHostName commands it seems that there is an email address and SMTP server available for it to use, but I’m a bit stumped as to what else I need to change?
Any help would be greatly appreciated
Thanks
Tarun
@tarun.chapman - The default values for sender address and SMTP server used by the HSLUtilLib email functions are set via the system configuration editor. The same library also has commands that can overwrite these values from default, if desired.
The config editor can be accessed from the method editor and run control toolbars:
Or you can launch it directly from the Hamilton Bin folder of your VENUS install:
In the system settings section, you will find the email configuration settings:
Admittedly, the currently available configuration options are not sufficient for sending emails to/from servers requiring SSL encryption and SMTP port configuration (like gmail), in addition to standard user authentication. However, this will be remedied in VENUS 6, which will allow for more configuration options and should allow for the ‘SendEmail’ command of the HSLUtilLib to function with such servers.
In the meantime, there are workarounds available that use custom libraries to mimic the function of ‘SendEmail’, but which use more parameters for server configuration. If interested I can follow up.
Great to hear about the improvements to email sending in VENUS 6, Nick.
Is there a list of back-end/developer improvements in VENUS 6 anywhere? Not the stuff like a reskinned operator UI, but the deep-dive programmatic stuff.
I’ve already signed up for the webinar on the 30th.
Thanks for the quick and informative reply. I’ve had a look at the configuration options and they all seem to be as they should but I’m still getting the error; I can only assume that the server I’m trying to send from requires the SSL encryption or something along those lines, which I don’t have a way of fixing.
I hadn’t heard about Venus 6 actually - when is it planned to be released, and will it be compatible with the Hamilton Microlab Star, which is the machine I currently have access to?
And yeah, any custom libraries that could mimic the function but get around the issues I’m having would be greatly appreciated.
Ah thats very informative thank you. Provided I do end up being able to use it on my machine, that looks like it has a lot of very useful and QoL features (especially a potential ctrl + z!).
Darn, I’ll have to wait for Venus 7 for that. Just out of interest, is there a particular reason it hasn’t been added?
Good to know. I’ll look forwards to getting the chance to play around with the software as soon as I can get my hands on it.
The feature was never developed - I don’t have more insight on it. I can confirm it is planned for future releases though.
In the meantime, Save and Save As often and use the Disable Steps functionality instead of deleting commands in your method. So, you can make a copy of the commands you want to edit, disable the older commands, and when the newer commands look good, you can safely delete the older ones.
As you mentioned, it is likely a security setting. Some servers require a different SMTP port as well. 25 is used by default, but some servers require 587 or 465, which may also be contributing to the error.
Below is a link to a custom library that facilitates ending emails via VENUS, through servers requiring various levels of security and encryption. Just paste the extracted folder from the zip into your Library folder.
Using a Gmail account to send automatic emails is a popular implementation in the VENUS universe, so I am going to demonstrate and example tailored specifically for that. Of course, there are highly varying IT restrictions out there, so your company may require use different email server. In that case, I would google the various server requirements.
Set up a Gmail account and use the following instructions to enable the mailbox to be accessed by third party applications. This will generate the password used for authentication.
If your team standardizes on a shared email account to use use for auto emails, the highlighted variables can be written into a modified version of the library (or pulled from the configuration or a file), to cut down on the number of required parameters. This would result in only needing parameters for recipient, subject and body (which would emulate the Util::SendEmail function).
Apologies for the delay in getting back to you. I’ve done as you recommended and installed the SendEmail library and tried to set it up as you suggested, however, it simply gives me the error of “message couldn’t be sent”; I’ve tried using the different SMTP server port numbers and it does nothing either. I’m not sure exactly what in the process is going wrong…
@tarun.chapman - I can’t really provide much further support without a pkg of the method you are using to attempt to have VENUS send emails, however you would need to remove the password using before sharing, which is a grey area at best for supportability.
For the new GMail account you set up for this purpose, did you enable emails to be sent via 3rd party applications, which generates a specific 16 character password to be used through VENUS?
No worries, you’ve already been incredibly helpful. I did generate the password for venus yes, and all my parameters are set to strings. I’ll keep troubleshooting and see if I can find the root of the issue.
