Numpy with PyLynx VVP
PyLynx VVP arrays inherit from Pandas (and consequently Numpy) dataframes, so you can use the same notation for modifying them.
Initializing a VVPArray object creates an 8x12 dataframe of all zeros:
    0    1    2    3    4    5    6    7    8    9    10   11
A  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0
B  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0
C  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0
D  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0
E  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0
F  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0
G  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0
H  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0  0.0
You can reference ranges in this dataframe with the .loc method:
array.loc['A':'C',] = 20.0
array.loc['F':'H', 1:4] = 100.0
print(array)
A  20.0   20.0   20.0   20.0   20.0  20.0  20.0  20.0  20.0  20.0  20.0  20.0
B  20.0   20.0   20.0   20.0   20.0  20.0  20.0  20.0  20.0  20.0  20.0  20.0
C  20.0   20.0   20.0   20.0   20.0  20.0  20.0  20.0  20.0  20.0  20.0  20.0
F   0.0  100.0  100.0  100.0  100.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0
G   0.0  100.0  100.0  100.0  100.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0
H   0.0  100.0  100.0  100.0  100.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0
This can get passed to VVP commands as the array variable
lynx.aspirate_96_vvp(plate = plate, array = array)
gamechanger for hitlisting. That’s ridiculously easy.
Right! And you can take an existing pandas df and initialize on that as well. For example:
data = [[10*col] * 12 for col in range(8)]
df = pd.DataFrame(data)
array = VVPArray(df)
A   0   0   0   0   0   0   0   0   0   0   0   0
B  10  10  10  10  10  10  10  10  10  10  10  10
C  20  20  20  20  20  20  20  20  20  20  20  20
D  30  30  30  30  30  30  30  30  30  30  30  30
E  40  40  40  40  40  40  40  40  40  40  40  40
F  50  50  50  50  50  50  50  50  50  50  50  50
G  60  60  60  60  60  60  60  60  60  60  60  60
H  70  70  70  70  70  70  70  70  70  70  70  70
