Yes, you can either provide a liquid class as a single element of an array ( to be used by all channels), or you can provide an array of liquid classes where element LCs are applied individually to each channel. The following post provides a more detailed explanation:
Thanks for getting back to me. Please also add the change in search box (not sure how this is for Venus6), in Venus5, the search box unfolds all possible labware and only highlights the relevant ones, in which the unfolding icons ā+ā & ā-ā are blocked due too lack of space. In contrast to Venus4, which gave the right search results based on input.
For the single step Pipetting steps it is. I actually have this implemented in a method that aspirates and dispenses with multiple different tip types at the same time.
Allow us to export all liquids used by a specific method in a txt/csv/xls file like this:
Line | Operation | Liquid
line 1 | Aspirate | Waterā¦
line 50 | Aspirate | Serumā¦
Is there anywhere all of the new features in custom dialogs are explained? The programming guide I have has basically zero updates to the dialog section. I can guess at some of the features, especially the straightforward ones like aspect ratio, but sometimes the details arenāt what Iād assume so Iād like to make sure.
This is technically possible, but it requires modifying the registry so fair warning not to modify other items as there is a risk of messing up the installation!
You can change the directory by going into the Registry Editor and to the following path:
Is it possible to edit what is output standard on a logfile line? Right now its just: 2024-04-08 18:53:59> MicrolabĀ® STAR : Communication - progress; Connection to instrument is created.
Ideally weād like to slap the method name, computer name, etc on each line. CoolTESTMETHOD computerID42 UserName 2024-04-08 18:53:59> MicrolabĀ® STAR : Communication - progress; Connection to instrument is created.
Then push this data to a data lake for tracking purposes, then we could replicate what Tecan does right now with Introspect somewhat. Itās frustrating to do right now as each logās name is a unique identifier, but the lines inside the files are not unique making the parsing of the upload challenging.
If you run multiple Stars at the same time you canāt just open each file and dump the contents, you have append the file name to each row to make it unique etc. Or do a look forward in the file grab the STARās serial number then append it to each row. You can do this at multiple points after the file is created but it is extra data manipulation/pre-processing that Iād rather not have to do.
For example if I were to dump 4 Starās log files that all ran at the same time with no manipulation you would not be able to tell which command went to which Star! You have to do some pre-processing to the log files making each command unique.
I would like to be able to just do a simple query of star name and errors, with no data manipulation to the log files. Maybe Iām just being picky haha
Sorry, I still donāt understand. The log file for each run will be unique, and in that file there is a robot identifier etc. Even if you have simultaneous runs, and you have configured the log files to be output into a network share or something, the log files themselves will be unique.
Are you doing this all on-line (as in as the file is being written) or something? What language are you doing this in?
